turbo exhaust housing
- gregT
hi, i would like to find out if a bigger exhaust housing than the standard would throw the shafts balancing out? ive got a T28 exhaust housing on the T25 turbo. thats all that is different from the T25. thanks
- Speed breeder
- 0.7 Bar Boost
Please excuse my ignorance...but how do you measure the size of the exhaust housing. The reason I ask, is because I know you get different size housings for a T3/T4 turbo for example (I think .90 and .95 or something).
I would like to eliminate some lag on my car (only spools up at 3800rpm on cold days)
Seems to be a popular misconception that the A/R is a fixed size. Its not its a ratio.
It is measured from the centre of the wheel to the centroid of the passage leading to the wheel.
You can have 2 phyiscally dissimilar exhaust housings with the same A/R.
Its normally cast into the exh housing. There are a few factors influencing turbo spoolup.
Exh wheel size
Exh housing A/R
Compressor wheel size
Exh manifold design
Wastegate design
State of tune
Boost controller
There are a lot of turbo "experts" out there and it seems most of them know just enough to turn your car into a dog. The hot stuff is a T3/T4 no matter the application or engine size and always with the biggest exh wheel and compressor to be found.
The other hotness is to take a tiny little turbo and drive it beyond its design speeds by trying to boost 2 bar from it.
Turbo's are like camshafts, be conservative and you will have a nice smooth power curve and car that is a pleasure to drive.
Exh wheel size
Exh housing A/R
Exh manifold design
Wastegate design
State of tune
Boost controller
