Rockford fosgate items
With a very heavy heart im selling my rockford fosgate sound that was for my sx :cry: :cry: :cry:
bought the amp was one month in my toyota so amp still new and comes with birth certificate.
I payed 10k for the amp ill let it go for 8K
Price.Power Specifications - Full Range Channels
RMS Power @ 4 ohms 125 watts x 4 channels
RMS Power @ 2 ohms 250 watts x 4 channels
RMS Power @ 1 ohm 375 watts x 4 channels
Bridged RMS Power 750 watts x 2 channels
Peak Power Output 1500 watts x 2 channels
Amplifier Specifications
Number of Channels 4
Total Peak Power Output 3000 watts
Total RMS Power Output 1500 watts
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged 2 ohms
Speaker Level Inputs No
Preamp Outputs Yes
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 40 - 4000 Hz
Low-Pass Crossover Frequency 40 - 4000 Hz
Bass Boost 0 - 18 dB
Bass/Gain Remote Included
Fan Cooled Yes
Amp lenght 84cm
The supplied remote frequency and level control can be installed anywhere for easy tuning. Power series amps feature a built-in 24 dB /octave slope high- or low-pass crossover continuously variable from 40-4,000 Hz and a switchable subsonic filter to help protect smaller subwoofers.
Rockford's Trans ana (TRANSconductance Active Nodal Amplifier) MOSFET circuitry simplifies the current and voltage gain. How does the Power amp deliver such a wallop of energy to your music? The answer lies in Rockford's innovative Variable Voltage Power Supply Optimization, which lets the amplifier operate with more flexibility than tightly regulated power supplies.
The result is sound so clean and bass so tight you have to hear it to believe it. When the bass does hit, you can count on the Power amp to keep its cool. The completely redesigned, focused mass die-cast heatsink has an internal cooling plenum and variable speed fan for efficient heat dissipation - even at 1 ohm! The removable front panel covers all connections, including the massive 1/0 gauge power terminals with integrated ANL fuse.
Features
•CEA 2006 Ratings for Real-World Power and No Bogus Specs
•Variable 40-4,000 Hz Low-Pass or High-Pass Crossover
•24 dB / Octave Linkwitz-Reilly Crossover Alignment
•Variable 35 70 Hz Bass EQ
•Variable 0 18 dB Para-Punch Boost
•Switchable 28 Hz Subsonic Filter
•Removable Connections Shroud
•1/0 Gauge Power and Ground Connections
•Built-In ANL Fusing
•Preamp Outputs
•1 Ohm Stereo / 2 Ohms Mono Stable
•Wired Remote Para-Punch Bass Control
25 farad rockford fosgate cap and comes with rockford fosgate discharge lead.
Price: R2000
Rockford fosgate base booster
Rockford fosgate T162s power splits6-1/2" 2-Way Component System
Power Handling:
Peak: 400 watts per set / 200 watts each side
RMS: 200 watts per set / 100 watts each side
Hard anodized parabolic aluminum cone woofer
Foamed rubber surround
1.1" Inverted hard anodized aluminum dome tweeters
Cast aluminum basket
Aluminum former
Embedded tinsel leads
4 ohms impedance
Cast aluminum audiophile 12dB LP/24dB HP crossover
Tweeter attenuation
Multiple tweeter mounting configurations
Price:R1000
comes with all covers and cross over box
Rockford fosgate T1 15inch d4 sub
•15" Power Stage 1 Series Subwoofer
•Power Handling:
◦Peak: 1200 watts
◦RMS: 600 watts
•Aluminum parabolic cone woofer
•Thermoplastic rubber surround
•Dual cast aluminum basket with spider venting
•Dual 4-ohm voice coils
•Double stacked magnet motor assembly
R2000
Re: Rockford fosgate items
Bump
cap sold
splits sold
sub sold
Amp still up for grabs.
