Water pump pulley
Water pump pulley
I baught a new water pump for the Ca 18, the new water pump has a smaller "shaft" that fits through the hole of the pully, my problem is bacause of the smaller "shaft" the pulley can not be sentered properly so it is a bit off balance, does anyone have a water pump pulley that fits the after market waterpump?
Re: Water pump pulley
uhhm, that didnt happened to me.Draco wrote:I baught a new water pump for the Ca 18, the new water pump has a smaller "shaft" that fits through the hole of the pully, my problem is bacause of the smaller "shaft" the pulley can not be sentered properly so it is a bit off balance, does anyone have a water pump pulley that fits the after market waterpump?
did you not get the wrong waterpump?
or maybe the pulley from the car its designed for will fit properly.
i got my new water pump from midas or something, and it fitted nicely!
Yo got the Ca18De water pump so you will need a Ca18de pulley
This will NOT hold the weight of your fan.
The best thing to is go to midas an buy a Ca20E water-pump same as the new era skylines.
This has a thick shaft and will NOT hold the fan
why would you want a thicker shaft that still cannot hold the fan?Phinx wrote:The thick shaft...
hmmm, i dont have the viscous on, and maybe thats why i have no problems with the water pump.
do you mean that even the thicker shaft water pump will break with the weight of the viscous on it!???!
Yep...
You need the tick shaft for the balance .
To keep yous stock Pulley.
I have had a number of pumps fail. Only oem can hold the fan.
But its cheaper to buy electric fans and a cheap pump
sorry for my sarcastic comment. the database must've gone wonky for a bit there.
your new post was an exact copy of the previous one.
unless you edited yours after i made mine.
oh whatever - apologies anyway!
Dont Worry Im Wonderboy....
I get allot of sarcastic comments....
yeah, mine was a GMC come to think of it. works fine for me, but i do have electronic fans!Daniel wrote:Got my aftermarket waterpump from autozone...its that japan make GMC or whatever. been working fine for over 2years with the standard fan still. and was a perfect fit, also for some or other skyline
the part number is actually on the parts section of the webpage!
