ca18det turbo swap to sr20 turbo.. bolt on ?
NITRO-P
Newbie
Real Name: Pieter
Post by NITRO-P »
Can any one please tell me on my stock ca18det if i can bolt the stock sr20 turbo on????
is it a straight bolt on??? do i need to to tune the car???? how mutch more power ?????
Re: ca18det turbo swap to sr20 turbo.. bolt on ?
should be a direct swap. dont know what power gain you get but u do get boost up until limiter the is no dip at the end no need to tune the car but if you have aftermarket management best to get it tuned you will get more out of it
NITRO-P
Newbie
Real Name: Pieter
Post by NITRO-P »
Thx, what else is a cheap bolt on option that's in the market?
Psyke
Post by Psyke »
Anything with a T2 flange should bolt straight onto the stock exhaust mani of the CA18. But if it will work well is another question entirely, including power gain. As SonOfAnarchy ZA said you will have to get it retuned to get the most out of the new turbo.
You can look at the SR20 turbo, or you can look at something more expensive like the GT2871R from Garrett. Hope that helps.
Boost Loading ......... Please Wait.
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Bolts on, but you have to clock the turbo a bit, also the front housing is not exactly the same so you will need to have some rubber pipes in hand to mod that to the air box
