Motor hasn’t been open. Started smoking and pulled out of car. I assume Rings
Extras Fitted when i used the motor
Greedy Cam Belt
OEM Water Pump
Cometic MLS exhaust gasket reusable
New exhaust studs
Otherwise here is what’s inc:
Oil pump
Pistons
Rods
Crank
Block
Head
Cams
Tappet Cover
Coil Packs
Coil pack Harness
Coil pack Cover
Ignitor Module
CA18 Cas with 6cyl dicktator disk
Injectors + Rail + FPR
Injector Harness
NO Intake Mani – Everyone buys aftermarket anyway
Exhaust mani
RB25 Alt
CA18 PS
OEM Cambelt
Want 3k for it, taking up space and I am not going to use it.
Will strip if there is interest.
RB25 Engine
- rat
- Real Name: Rat
RB25 Engine
Re: RB25 Engine
if only i was in margate. what would it cost to get to jhb?
- DriftZ
- Car: S15
Re: RB25 Engine
id guess between R800 - 1kSonOfAnarchy ZA wrote:if only i was in margate. what would it cost to get to jhb?
- k.y.l.e.
- Real Name: kyle
Re: RB25 Engine
very good price!!!
