Early Christmas gift
Cometic HG
Cometic HG
So dudes, who's got a cometic HG laying around, 1.5 mm by 83.5 or 84 mm. Here's the catch, I only have R1000
Re: Cometic HG
remember to make sure that your head AND block is PERFECTLY flat , otherwise your multi layer stainless steel headgasket is gonna make you cry..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
antman
- Engine: VG
- Real Name: Tony
Re: Cometic HG
This is correct....this is very correct. Block and head must have a 50RA finish as Cometic specify or you will have leaks.I asked a reputable motor engineering comany to give my heads and block a 50 RA finish and he asked me what is that.300sx wrote:remember to make sure that your head AND block is PERFECTLY flat , otherwise your multi layer stainless steel headgasket is gonna make you cry..
Re: Cometic HG
Thanks for the advice guys, knew that part but was gonna fly by the seat of my pants hahahaha..doesn't really matter if I don't get a cometic HG does it...
Antman...don't use those engineers!!
Re: Cometic HG
spray some copper gasket sealer on both sides of your metal head gasket before putting it on and there is a lot less chance of a leak.
Re: Cometic HG
Thats what I did last time, I think my arp head studs was to long so it could not be tightened proparly.
