Bigger AFM
johansx
Bigger AFM
Post by johansx »
The exhaust side of my S14 if almost sorted, but the inlet is a bit choked. Can get a MAF from a VG20 which I believe is the same as the RB25DET unit. Nice 80mm hole and 3 pin plug, easy to convert to the std S14 4 pin-3 wire plug. While I am at it, also fitting a bigger throttle body, also about 80mm in size.
The part no for the MAF is : 22680 31u00 a36-608 e60
Lots of stuff on Google, bit nothing definite on a SR swop. Any tried this one b4?
Engine code Frame ID Est. Power Color Pin## Size
CA18DET S13 22680-D6000 190HP 3pin 60mm
SR20DET N14 22680-54C00 280-290HP 4pin 65mm
SR20DET S14 22680-69F00 280-290HP 4pin 65mm
SR20DET S14a/S15 22680-69F01 280-290HP 4pin 65mm
SR20DET PS13 22680-52F00 290HP 4pin 65mm
RB20DET R32/R33 22680-02U00 300-310HP green 5pin 76mm
RB20DET/ RB25DET ECR33 22680-31U00 350HP purple 3pin 76mm
RB26DETT R32GTR/R34 22680-05U00 310HP pink 5pin 70mm
RB20E/DE/ DET/RB25DE R32/R33 22680-02U00 300-310HP green 5pin 76mm
RB20E/ RB25DE/ RB25DET ECR33 22680-31U00 350HP pink 3pin 76mm
RB25DET ECR33 22680-31U05 pink 3pin 76mm
VG30DE R31 22680-16V00 purple 76mm
VG30E/ VG30ET Z31 22680-25P00 blue 76mm
VG30DETT Z32 2680-30P00 450-500HP orange 6pin 76mm
VG30DE/ RB20DET HR31 22680-16V00 purple 76mm
Infinity Q45 22680-61U00 350-400HP yellow 3pin 90mm
Post by Vlade »
From what I've read is that you need to "update" the ECU in order to read the new MAF... its like changing injectors can't just plug a bigger one in 8)
johansx
Post by johansx »
Unicrap... sorry, Unichip fitted. :wink:
johansx wrote:Unicrap... sorry, Unichip fitted. :wink:
LOL :lol:
