R32/Z32 front brake swop.
so i read on sxoc.co.uk that you can use the e36 M3 discs for your R32/Z32 front brake swop.
the front rotors have similar dimensions, 'cept that they are 315mm diameter as opposed to 280mm.
but the spares shops dont have locally manufactured (alpha) discs available for the M3.
the comparison is as follows.
E36 / 300
A (dia) 315 / 280
B (bore) 162 / 154
C (offset) 53 / 54
D (thickness) 28 / 28-30
and the thread also has an adapter plate diagram to spacer the calipers to fit the 315mm disc.
what to do now, other than sit for hours going through the alpha brake catalogue?
E36 / 300
A (dia) 315 / 280
B (bore) 162 / 154
C (offset) 53 / 54
hey gary,
found this site:
http://www.alfabrakes.co.za/catealogue.php
and scrolling down slowly found this:
infiniti Q45, 1997 onwards.
part number 40206-0P600
height = 53.7mm
diamter = 280mm
spigot diameter = 68mm
max thickness = 28mm
min thickness = 26mm
weight (net) = 7.96kg's
found this site:
height = 53.7mm
diamter = 280mm
225mm or 325mm - i'm guessing 325mm.Gary57 wrote:NOPE, my 225mm discs leave me with about 5mm clearance between the caliper and mag. I also had to modify the caliper to take the bigger disc, anything bigger than 280mm with require some modifying.gawd - will 343mm with calipers fit under my 17 mags???
and i know about the modding - thats not the problem. the problem is the trying to get a locally manufactured disc.
so i should look for something of 325mm or less, and 280mm or more!
- n1smo200sx
- 0.5 Bar Boost
yes i know about this stuff!!! you take me for a nana hey???Gary57 wrote:Do you know what mods it takes to get the 325mm disc to work in the Z32 caliper??
The problem is the disc rubs on the caliper even when the spacer plate is in. I had to use a milling maching to mill down the insides of the caliper.
anyway - found some more options because i went through the entire catalogue, i've got them on a spreadsheet.
the two closest matches are:
1. kia sorento 4x4. this is a nice match because the disc height is perfect, and the diameter is 302mm. but the disc max thickness is 28mm.
2. VW t5 transporter tdi 16" wheels. this is a nice match because the disc thickness is perfect at 29.5mm. but the disc height is 55.5mm (1.5mm taller than the zx disc). its also 307.8mm diameter which is nice!
