ca18 slight misfire
Posted: Tue May 28, 2013 9:59 pm
by Keagz
so iv looked at previous threads and nothing relates 100% to my problem so hopefully i can resolve it, i got a ca18det and it drives fine (had a dump valve on when i got the car but i took it off) but when i floor it and put the car into neutral then the revs drop to about 300+- (with a misfire) if not dies and then goes back up to about 850revs... does any1 know the solution to this?
Re: ca18 slight misfire
Posted: Wed May 29, 2013 7:02 am
by Grant222
when mine did that I cleaned all the electrical plugs and ground connections in engine bay(that was my problem), or it might be the temp sensor to ecu faulty
Posted: Wed May 29, 2013 8:06 am
your neutral switch is faulty
Posted: Mon Jun 17, 2013 8:54 pm
by Adrian
check your tps unit is not lose and moved position. its located on your throttle body. mine messed me around hunting to idle that.
