ca18 slight misfire
ca18 slight misfire
so iv looked at previous threads and nothing relates 100% to my problem so hopefully i can resolve it, i got a ca18det and it drives fine (had a dump valve on when i got the car but i took it off) but when i floor it and put the car into neutral then the revs drop to about 300+- (with a misfire) if not dies and then goes back up to about 850revs... does any1 know the solution to this?
- 0.9 Bar Boost
- Engine: 2JZ
- Real Name: Grant Jones
Re: ca18 slight misfire
when mine did that I cleaned all the electrical plugs and ground connections in engine bay(that was my problem), or it might be the temp sensor to ecu faulty
your neutral switch is faulty
- 0.9 Bar Boost
- Real Name: ????
check your tps unit is not lose and moved position. its located on your throttle body. mine messed me around hunting to idle that.
