clean out
clean out
Got the following for sale
1.CA18DET Altinator R700 Sold
2. CA18DET Starter R700
3. CA18DET fan Stroud R250 sold
4. CA18DET Stardard pistons and rods R500
5. CA18DET block R500
6. CA18DET should have a radiator soon R700sold
7. CA18DET ignitor and boost cut valve R450
8. CA18DET AFM R550
9. CA18DET water coolant sensor R150sold
10.CA18DET aircon pump R450
11. i Think its a Rb CAS R500
12. ABS unit?
13. CA18DET standard fuel pressure regulator R250
8. CA18DET AFM R550
12. ABS unit?
Last edited by SonOfAnarchy ZA on Mon Nov 18, 2013 11:37 am, edited 2 times in total.
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Re: clean out
Hi Bud
Reserve the block for me please? How does the sleeves look
Re: clean out
block is not i great condition might need to resleeve it can get pics tonight for you if you want
Re: clean out
kwl will bring it round when i fetch the bonnet unless its urgentBigKriss wrote:ill take that alternator bud.
Re: clean out
Nope, all cool, thanks.SonOfAnarchy ZA wrote:kwl will bring it round when i fetch the bonnet unless its urgentBigKriss wrote:ill take that alternator bud.
Re: clean out
Please post pics of the radiator shroud? If its un scratched and perfect ill take it.
Re: clean out
There a couples scratches on it Gary sorry bud
Re: clean out
bump
Re: clean out
Fan shroud? As in this:CA18DET fan Stroud R250
If so, could you post a pic or two?
Die fantoom van die oop parra
Re: clean out
thats the one will post pics later for you
Re: clean out
bump
