PP XMS 3 Miss on pulling away
Posted: Mon Apr 22, 2013 12:29 pm
by Ero_sennin
As the tittle says, my sx misses upon pulling off from stand still at light throttle. What would I need to tune to fix this?
Re: PP XMS 3 Miss on pulling away
Posted: Mon Apr 22, 2013 12:58 pm
My bet would be it's lean there.
Posted: Mon Apr 22, 2013 1:01 pm
by Ero_sennin
hmm could be will get the laptop and give that a go!
Posted: Tue May 14, 2013 12:37 pm
is perfect power a good system? how do you find it?
Posted: Tue May 14, 2013 2:39 pm
by Ero_sennin
Not bad, has some nice features other local managements don't have. ie: AUX outputs for vvt, fans, boost controller, etc.....
Can use a O2 sensor for adjustments.
Has enough map points and each one can individually adjusted. Compensation for cold start etc... too
I think its one of the better local systems available.
I personally tho would rather recommend Apexi power FC(very very good,but not cheap) or even adding Nistune on the stock ECU. You keep all your existing sensors, no cutting and fiddling with wiring harness and you have a huge amount of options to adjust.
Stock ECU's are light years ahead of aftermarket ECU's of the amount of what it can do. So adding the ability to be able to edit the maps make them brilliant!
Posted: Sat Sep 12, 2015 4:34 pm
by SILVIA_S14
Who knows who tunes Apexi's on the sx's ?
