PP XMS 3 Miss on pulling away
Discussion of Managements and Mapping
Post by Ero_sennin »
As the tittle says, my sx misses upon pulling off from stand still at light throttle. What would I need to tune to fix this?
Re: PP XMS 3 Miss on pulling away
My bet would be it's lean there.
hmm could be will get the laptop and give that a go!
is perfect power a good system? how do you find it?
Not bad, has some nice features other local managements don't have. ie: AUX outputs for vvt, fans, boost controller, etc.....
Can use a O2 sensor for adjustments.
Has enough map points and each one can individually adjusted. Compensation for cold start etc... too
I think its one of the better local systems available.
I personally tho would rather recommend Apexi power FC(very very good,but not cheap) or even adding Nistune on the stock ECU. You keep all your existing sensors, no cutting and fiddling with wiring harness and you have a huge amount of options to adjust.
Stock ECU's are light years ahead of aftermarket ECU's of the amount of what it can do. So adding the ability to be able to edit the maps make them brilliant!
SILVIA_S14
Post by SILVIA_S14 »
Who knows who tunes Apexi's on the sx's ?
