Here are some pics how they resolve the problem:
Before it was corrected.
After it was corrected.
BigKriss wrote:Bud, I have searched till the Earth`s end on the intewebz and found a ton of things that could go wrong.
If I had worried about all of that I would not have gone RB and simply put my Lexus V8 Turbo in..
I have the NEO engine from an importer, rev limit is set at 7800 and boost up to 1.5 bar.
I use my car and the engine works hard.
I have not had a peep or a fart from my engine ! I have a new found respect for Nissan engine`s.
+ plenty !RB25SX wrote:Just buy a RB25DET NEO.
I had both the old RB25DET and NEO. NEO is a much better motor stock. Stock turbo @ 0.8 bar about 225kw , 350nm.
GT3076R or GT35R + injectors for 300kw+
rat wrote:There is some oil problems. Depends on your use. If you going to be using it stock then I would bother.
The crank collar. Very difficult to say your motor has it fix from the factory unless it is a R34 motor. Seems it kill the oil pump at high revs.
External Oil drain mod. Again depends on use.
Oil restrictors mod. Oil build up in the head holding high revs.
Don't use the N1 oil pump. Use stock or a name brand like tomei or greedy.
