Timing
Timing
Among the many problems i got i noticed this the other day and didnt know what to make of it. while checking my timing as i rev the car the timing changes according to the timing light is this right?
Re: Timing
Yes, timing will change based on throttle position, load, rpm, etc.
Re: Timing
ok thanks now i just got to figure out what is knocking in my motor hopefully not the bearings
- phoenix s14
- Real Name: Mark Appelgryn
Re: Timing
Well diagnose the conditions first. Is it doing it when hot or cold, full throttle or 1/2 throttle, etc etc etc
Re: Timing
ok so far on idle its not there as i rev a bit i can hear it but doesn't get louder the higher i rev but its very soft sound will run the car this weekend and see if it remains there when the car is hot
- phoenix s14
Re: Timing
Well that could cause more problems... bit of a gamble... if you dont already know then I suggest you take a listening rod and try see where it is coming from. If it is from inside the engine then I would rather then gut it anyway. Sorry hope its not what you think...
Re: Timing
if i drain the oil then surly there will be metal flakes in it if the bearings are shot
