Turbo tappet cover R100
Timing belt (power grip) new R80
Water pump (murl) new R150
Rings std (hastings) new R150
Big end bearings (ae) new R100
Oil cooler + new seals turbo R250
Oil cooler no seals turbo R200
Dipstick + Tube R50
Main bearings std (power torque) new R100
Steel water pipe R50
Fan belt new R20
Distributor cap + ht leads turbo R150
Oil pump (power torque) new R100
Jackshaft (lightened)+gear (turbo only) R150
Crank std knife edged Turbo R800
Waterpump pulley R50
2X Alternator aliminium bracket R50 each
2X Oil pickup R50 each
Rear brake shoes new turbo R100
Set radiator fans turbo R200
clocks Normaly aspirated R150
Intake with throttle R150
complete air pipe(LOG) with air regulator and idle speed valve R150
2X secondhand oil pumps working order R80each
2X thermostat housing R80 each
jack shaft+pulley R150
4X Pistons & conrods std turbo no rings R400
4x pistons & conrods std turbo with rings R400
4x Pistons & conrods .20 over size no rings R400
Rear engine mounting R200
2X side engine mountings R150 each
Throttle body std Turbo R150
1x Knock sensor turbo R50
2x Flywheel std turbo R150 each
Complete head + intake+thermostat housing+throttle bode+std fpr+injectors R850
2X engine rear main oil seal R50 each
2X tappet covers Normaly aspirated R50 each
window washer bottle R80
Distributor Normaly aspirated No Cap R400
Driver side, side mirror R150
boost pipes std set R150
airbox standard R200
alternator adjust bracket R50
Gearbox + starter + sanwichplate turbo R2800
Block and sump with crank std turbo R1000
block and sump decked and O ringed std bore turbo R1200
3x Cams std R200 each
Head (bare) normaly aspirated R350
2x presure plate with clutch plate second hand good for 0.5boost R250 eac
contact robert 083 331 9371 bbm 26bb9fc8
Nissan EXA Turbo parts
