Does anyone know if a std 200sx CA gear box fits on a SR20 Black top motor? also does it work?
Shot okes!!
CA Gearbox on SR Red/black top?
- Drillergy
- Real Name: Darryl
Re: CA Gearbox on SR Red/black top?
fits perfect but you need a SR Rwd bellhousing.
You also might have clearance issues with the clutch slave cylinder depending on which slave you have.
balls, where can i get one? are they hard to come by?
harleyzx1400
- Real Name: Harley
Hi, Twakkie, I think you are gonna sukkel a bit to find one. They are better because the revs in top drop nicely with the SR box. At 120km/h I am doing a fraction over 3000rpm, which is nicer than with the CA box. Buy a motor and box combo. The CA box will work but you need a SR 20 bellhousing. Cheers.
