Project s13 RB25 Neo Capetown
Re: Project s13 RB25 capetown
Got my new turbo today Mr turbo ball bearing T61
TW15 turbine wheel(10 blade)T4-2,5 (61,7mm-74mm)
Turbine housing T3 A/R.63
Compressor wheel T61
Compressor housing A/R.70
Backplate T04E big shaft anodised
Hoping for 300kw at the least.
Update
Motor in an on its place with turbo fitted :D
Turns out the s13 clutch resivor works by a 10mm gap but still going to fit the s14 one soon
Sand blasted the fuel rail and caps before an after pic of the sand blasting
DARRYL J
Real Name: Darryl Joseph
Post by DARRYL J »
Looking schweet Kyle
Keep the pics And updates coming. :domo:
:? intake will need to come off if you ever have a master issue. but project is coming along nicely with that big ass turbo u should hit 300kw, what management you gonna run?
Thanks at darryl j and will keep updating
@ SOA intake does not need to come off as the clutch resivor can pop in and out with the intake on its place only problem is if i have to take the intake off i must take off the clutch resivor but getting an s14 one soon.
pics of the items that got sand blasted
Throttle body sand blasted aswell was stained badly
Got a bit of problem bought these injectors from antman on the forum was told its direct bolt in the rb25det fuel rail but turns out its missing the damm o-ring and pintle cap on the tip of injector does anybody know were i can get the pintle caps.
On the left is stock rb25det injector on the right is the stock rb injector moded to 740cc.
mario_200sx
Post by mario_200sx »
Just make sure that there is no sand particals left inside the fuel rail...... Its scary how these particals go sit in the smallest areas....
mario_200sx wrote:Just make sure that there is no sand particals left inside the fuel rail...... Its scary how these particals go sit in the smallest areas....
Will do going to blow it out with high pressure air.
lil update
Bought a piece of billet aluminuim 100x100x20
Test fit, drilled the big hole with a 60mm hole saw an a full tin of cutting fluid lol and rounded off all the edges.
Made the two top holes counter sink to clear the throttle body
How it looks fitted :D
All holes was spot on really happy about that, just two more holes to drill and its done.
Real Name: ????
Post by Adrian »
looking good dude
thanks @ adrian lots of time and effort
Had to make new fan bracket as fans sit infront of the rad now no space in front
Got some bits polished came out real nice :)
grinded the ar70 and m24 sign off housing to have a smooth finish
Got a tial 38mm external wastgate
Getting there
Sprayed the stock fuel rail with blue metalic engine enamel spray.
