Project D - 1 DEC 2007
thats wikked news man...
it seems like we were waiting and waiting, and then BAM...
in it goes suddenly one day and is running!!!
awesome!
ChemCool
Post by ChemCool »
run baby run 8) 8) 8)
COOLER, FASTER, LIGHTER
Charl
Post by Charl »
ya you get used to it after so many times and the work just fffllooooooowwssssss. removing and rebuilding an engine for some of us is now like changing a flat tyre when we were younger
200SX Catch my DRIFT?
Post by Vlade »
Thanks guys... I'm actually very nervous every time I think about driving, its been a year of hassles... Hopefully she'll last :)
What was the problem?? What did you have to change to get it to start??
Post by Vlade »
I think my fuel relay is getting old, my fuel pump do not come on all the time... that stuffed me around and the flooding, I copied your settings and I also activate the flood clear function to clear the flood if the throttle is open more than 80%.
So did you use my starting settings or did you use my whole map??
Post by Vlade »
just the starting settings, for now... I want to start try your map today if everything goes well.
If you cant get it to start on my map (which I cant see why not) then you will have to manually copy all the settings :( .
Great to hear you are up and running!!!!!!! :wink:
Any luck with running it on my map??
Post by Vlade »
To be very honest... Nope haven't really tried :oops:
But I have been logging my trips so I can revisit the map and start tuning it, but before I try that I'll try your map...
But also remember you said that map I had was an old :wink: "Gary Starting 6 or something"
But also remember you said that map I had was an old "Gary Starting 6 or something"
Ok Ill send you the new one tomorrow, think it is GARYDYNO 1 STARTING 7 HB2 RT2. I think I fiddle to much :lol: . Oh that means it the 1st dyno tune I did, 7th starting map that has worked (must of done about 30), 2nd tune for high boost (1 Bar), 2nd road tune done to get the part throttles correct.
Post by Vlade »
Got your map to start up, it just runs very lumpy, I played with the timing and fueling trim to see if that won't smooth it out, got it idle okayish but when you ref it up it sounds like its missing.
Its too lean, your AFR should coincide with what I am saying. Remember I have a 5th injector which you dont. Click on fuel and adjust the overall trim, this will help it out. Unfortunately it is not 100% but should help out for now. When you tuning at least you now know that you much richen up the map (a direction in which to go).
Another thing which you could do is manually copy over your fuel map, teadious but will sort all of that out.
