ok, found a solution for the standard fitment of s13 tie rods.
regarding the fixing of the bump steer problem - found a solution available locally, but its not as cheap as i thought it would be, and requires modification of the wheel spindle!!!
anyways, check out the 200sx.za.net website for the part numbers soon, and check out the articles section for an tie rod and ends installation write-up.
