Page 3 of 4
Posted: Fri Jun 01, 2007 11:01 am
by Sokar
Can you spot the problem if your fifth or even one of the primaries fail when using a fifth injector setup?
And another thing, where's this injector gonna get fuel from? You gonna just Add a T to the line going to the current fuel rail?
Posted: Fri Jun 01, 2007 11:08 am
Phinx wrote:Lol on the ball Veecee :o
But to slow,(joking) 8) . I have already put the word out to the rotor guys but I'm awaiting feed back ...
The AFM going to be the mission , I have that feeling :evil:
the injectors - get rudi/stephan's number from sokar. and phone to ask them. otherwise call arthur. he'll have plenty lying around!
the AFM - there are a few out there that will work. i reckon your best bet is NZ or OZ, or the UK(although its huge bucks). all the larger nissan engines from sedans to 4x4's!!! the largest is the one from the 4.5 v8 IIRC!!!
call the engine importers - that's where we got a stock AFM from a mazda 13bt.
Posted: Fri Jun 01, 2007 11:11 am
by Sokar
[smilie=200sx_offtopic.gif] but VC, have you seen that your profile now says "Over Boosting" :P
Posted: Fri Jun 01, 2007 11:14 am
[smilie=200sx_offtopic.gif] but sokar, yes i have. have you been sleeping???
its been like that for weeks now!!! there are a few others too, like Gary!
but to check an injector, you can unplug it, or listen to it. to properly check it, go and have it flow tested and cleaned.
Posted: Fri Jun 01, 2007 11:18 am
If there are any fueling problems I will pick up through the EGT gauge.
Yip from after the fuel filter and before the fuel rail.
I know this is not the best set up but the Wolf can control a 5th injector very well and it is still the best bang for buck.
Posted: Fri Jun 01, 2007 11:34 am
by Phinx
Ok will do some research, I have asked Sokar to ask the Rotor guys if possible
I will see what other AFM can fit...
Posted: Fri Jun 01, 2007 11:36 am
by Sokar
Gary57 wrote: If there are any fueling problems I will pick up through the EGT gauge.
Again, Gary I'm not knocking your setup, it works and you're happy with it, but effectively you've just told phinx that to run a fifth injector he needs to get an EGT guage and a Wolf 3d system....
4 Bigger injectors are looking mighty fine at this point...
To me adding a fifth injector is like putting a bandaid on a cannon wound, if you wanna get more fueling, do it, do it properly, with a fifth injector you've just added 3 extra failure points into a working system, it doesnt make logical or financial sense...
Posted: Fri Jun 01, 2007 11:50 am
i struggle to see how phinx will fuel his engine properly without using some sort of fuel management add-on to his normal ECU.
even with bigger injectors instead of a fifth one, he will need to control them somehow.
Posted: Fri Jun 01, 2007 11:55 am
by Sokar
veecee wrote:i struggle to see how phinx will fuel his engine properly without using some sort of fuel management add-on to his normal ECU.
You are 100% correct, he has ordered something but is keeping very quiet about it...
Posted: Fri Jun 01, 2007 11:58 am
the knob...
i want to know about it! tell him to tell me!
Posted: Fri Jun 01, 2007 12:00 pm
by Sokar
veecee wrote:the knob...
Hehe, he first wants to see if it pans out before he makes any hype for it...
Posted: Fri Jun 01, 2007 12:22 pm
Thats why I said:
Oh ja but you guys dont have this housing.... Oh shit just ignore what I said, not thinking again, My bad.
Posted: Fri Jun 01, 2007 12:27 pm
yes - what he said!
Posted: Fri Jun 01, 2007 12:31 pm
by Sokar
Yeah, you did say that, sorry to keep harping on, but I really think a fifth injector is a very hillbilly way of tuning :P Unless you have all the supporting bits like Gary has...
Posted: Fri Jun 01, 2007 12:34 pm
Yeah I suppose it is a hillbilly way but then some say so is water injection.
