Thats a bargain where did you get it from???aep886 wrote:your local engine part~ i got mine for like R600...
that with the 2 cam gear... sproket... chain... chain guild... tensioner...
S14 rattle sound from the Head
is that the kit for the sr20de are they the same?Buckusa wrote:get this just called them its R855 incl vat! bargain! thats the entire kit includes the chain, guides, tentioner etc!Buckusa wrote:sweet thanks that an orignal nameaep886 wrote:the place is called: Engine Parts... they have few branch all over SAnow to get help to install it lol
Lol I was actually going to ask you guys because he said that the kit is the same for the SR20DE and the DET, is that true anyone?andre_sx wrote:is that the kit for the sr20de are they the same?Buckusa wrote:get this just called them its R855 incl vat! bargain! thats the entire kit includes the chain, guides, tentioner etc!Buckusa wrote: sweet thanks that an orignal namenow to get help to install it lol
- aep886
- Real Name: Davey
they are the same!Buckusa wrote:Lol I was actually going to ask you guys because he said that the kit is theandre_sx wrote:is that the kit for the sr20de are they the same?Buckusa wrote: get this just called them its R855 incl vat! bargain! thats the entire kit includes the chain, guides, tentioner etc!now to get help to install it lol
Thanks dude I hear you, there is still a slight rattle but only when it is very hot outside, nex thing I want to do is remve the upper timing chain guide I am certain that is still causing the sound.aep886 wrote:it a common problem on high mileage SR20det....Buckusa wrote:thought Id let you guys know, I just changed the timing chain tensioner and voila the sound is gonethanks for all the input guys!
later you will experience a similar sound then it your VTC gear
Red S14
- aep886
- Real Name: Davey
i am sure this time is the VTC gear^^Buckusa wrote:Thanks dude I hear you, there is still a slight rattle but only when it is very hot outside, nex thing I want to do is remve the upper timing chain guide I am certain that is still causing the sound.aep886 wrote:it a common problem on high mileage SR20det....Buckusa wrote:thought Id let you guys know, I just changed the timing chain tensioner and voila the sound is gonethanks for all the input guys!
ok I will check it out, if it is whats the fix?aep886 wrote:i am sure this time is the VTC gear^^Buckusa wrote:Thanks dude I hear you, there is still a slight rattle but only when it is very hot outside, nex thing I want to do is remve the upper timing chain guide I am certain that is still causing the sound.aep886 wrote: it a common problem on high mileage SR20det....
Red S14
There is a cheaper solution to try first (especially if it's in the early stages/light rattle)
The selanoid that you unplug is replaceable. The S15 SR's came out with a different design for this to cure the VVT rattle but they never did a re-call, nor did they admit to this
See here:
The one on the left is more than likely the one you have (old design), you need to replace it with the one on the right (new/s15 design). You can get these new from Nissan, or look internationally for it second hand (I can source if you need, just pm me).
It has cured VVT rattle 70% of the time in my experience, only time it hasn't is when the rattle was very bad.
See here:
