200sx s13 CA18DET - plugs and filter
Charlvdw wrote:Start by getting a adjustable fuel pressure regulator with a gauge that way you can see what you are working with. The gauge will also tell you if your pump can keep up.
It's already known that the pump can not sustain much more than standard.
JoKeR**
Post by JoKeR** »
riding my car like this wont mess it up will it??
It will if you do too long, till you can sort out the stuff, maybe it's best to put the standard air filter and so on back.
Just a question....describe where and how you installed the cone filter and adaptor...
JoKeR**
Post by JoKeR** »
at the place where i got the filter and they installed it for me, i watch them.
the basically just switched the two. why?
Did your car have the standard air filter box?
If its just the filter that changed you wont need a lot more. :roll:
JoKeR**
Post by JoKeR** »
yep it did. alfy, the guy that had the car before me, put a bmc flat pan filter in and now it has the cone in.
Ja pa....ma hy wil meer boost later....so die begin is die begin....pa...
JoKeR** wrote:yep it did. alfy, the guy that had the car before me, put a bmc flat pan filter in and now it has the cone in.
So they did connect the adaptor before the afm?
JoKeR**
Post by JoKeR** »
not sure. what did u do when putting your filter on? like step by step what did you do?
JoKeR**
Post by JoKeR** »
does anyone know what oil and what coolant the sx takes?
JoKeR** wrote:not sure. what did u do when putting your filter on? like step by step what did you do?
Best I think is to take a pic and post it.....
i say leave the std fpr and just fit a walbro pump. Sorted my problems out when i had a std sx
POWDER
Real Name: Mike
Post by POWDER »
I agree fully with poizen, manual boost controllers can make your car ping if you dont know what your doing there, or wors still, blow up in ur face. the electronic IS the best.
My friends Opel saw it's gat with a manual. We were playing with a manual tap controller and at first thought it wasn't opening so we opened it to far, then things went a little lob sided with oil all over the floor and plooms of smoke.
Advice, if manual, open click by click and test between clicks, even if it takes all day to get there... Need accurate boost Gauge to do this...
<<EDITED>> Nevermind, I see im a little delayed on this one....
