Charlvdw wrote:Start by getting a adjustable fuel pressure regulator with a gauge that way you can see what you are working with. The gauge will also tell you if your pump can keep up.
It's already known that the pump can not sustain much more than standard.
If its just the filter that changed you wont need a lot more.
I agree fully with poizen, manual boost controllers can make your car ping if you dont know what your doing there, or wors still, blow up in ur face. the electronic IS the best.
My friends Opel saw it's gat with a manual. We were playing with a manual tap controller and at first thought it wasn't opening so we opened it to far, then things went a little lob sided with oil all over the floor and plooms of smoke.
Advice, if manual, open click by click and test between clicks, even if it takes all day to get there... Need accurate boost Gauge to do this...
<<EDITED>> Nevermind, I see im a little delayed on this one....
