Fueling Fundi's
- Real Name: Renier
jdf
1=check all vacume hoses they do pop off(there where the turbo is and the littel bugger behind the head)
2=check coil packs one is on its way
3=afm is maxing out
when its holding back does the car miss and then its like boom its gone and coz when my coil pack went it done that
3=afm is maxing out
- Andrew.200SX
- Real Name: Renier
jkjfrv
then i will put my money on a busted coil pack
but just check all vac hoses coz it can do the same thing
try and borrow or buy some spare coils and change them out
you can test the coil but its a bit shocking if you make a bobo while the car is running un screw a coil pull it out a littel bit and check how strong the spark shoots .all 4 must be mostly the same but if its very week its fukt
dont drive the car to hard with busted coil coz it is over feuling the cilynder with the busted coil.from when it started has it gotten worse and hapening
more often?
more often?
- Andrew.200SX
- Real Name: Renier
m,cv
then check the coils verry soon when its hot its gonne start missing and going to stay like that then when you park and it cools its gonna start normal again.
also notice when it does does this when driving park and smell the shit load of unburnt feul in the zorst
- Andrew.200SX
If I must be perfectly honest, it sounds like you have been driving my car !!
LOL
Everything you are describing sounds spot on. The smell of fuel , I put down to the 1 injector that has a very , very slight leak. I thought that was what I was smelling, the bit of fuel on the intake manifold.
So , now the fun part , cost of coil packs + - ?
Thanks for your assistance
LOL
- Andrew.200SX
- Real Name: Renier
mcv
just for safety check the vac hoses the buggers do pop
can only use ca18det coils there is 4
sentra only has 1
at nissan coils is like R1000 each
2nd hand R200-R500 each
keep an eye on the problem if it gets worse when hot and try fix it asap
before BOOOOOOOM
sentra only has 1
before BOOOOOOOM
- Andrew.200SX
- Andrew.200SX
I just removed all 4 coil packs and tested the ohms and they are all giving exactly the same reading. I did notice that the insulation around the connectors on the inside wasn't to bright , so I sorted that out and the car is running 99% better now. I can still very , very slightly feel a little bit of a hold back through max boost , but allmost not noticeable.
Surely if one of the coil packs was faulty , I would have picked it up on the resistance readings ?
- Andrew.200SX
- Andrew.200SX
