Page 3 of 3
Posted: Thu Jun 25, 2009 2:30 pm
by poizen
KCSX wrote:how do i post a pic
get photo bucket and uplode your pics wait what for face book name ill add you
Posted: Thu Jun 25, 2009 2:56 pm
by KCSX
Kiyash Cherr Sha
Posted: Thu Jun 25, 2009 3:25 pm
by KCSX
just drove my SX to pine town a back and its pulling like a beast , so i guess it was the hot air that messed everything up , anyway are there any real to have Cone Filter ?
Posted: Thu Jun 25, 2009 5:38 pm
KCSX wrote:just drove my SX to pine town a back and its pulling like a beast , so i guess it was the hot air that messed everything up , anyway are there any real to have Cone Filter ?
you can always drill your stock airbox
Posted: Fri Jun 26, 2009 6:52 am
I cant see how youre car can get heatsoaked whiles driving if you are sitting in traffic yes but not constant driving.
Posted: Thu Jul 02, 2009 7:16 am
by Q-mech
Ya, that sounds like heat soak. A FMIC does help and I'm sure a cold air intake would help aswell, but being a turbo engine they do generate alot of heat. Water/meth would probably work best to combat this.
Water/meth will sort it out but maybe it's a bit extreame for a simple fix.
the standard IC is pretty crap yes, but after 15 od years of sucking in lint from the standard filter, you'll start getting a bit restrictive aswel. ask anyone who drove one of these new and they'll tell you the standard crap aint all that bad.
so you you want to try and fix the problem without moding the car simply strip the standard IC open it up(without killing the seals) and give it a clean, that should do the trick although it wont hurt isolating the air filter.
Reamember, 80% of heat soak is due to poor mantenance and can be fixed by a bit of TLC and the other 20% due to mods and you'd have to mod some more to fix this.
Posted: Thu Jul 02, 2009 10:36 am
by Pinkfluffybunnys
I disagree the standard IC is crap It will instantly suffer from heat soak after a one long boost run and doesn’t shed heat vey well.
Also the item is very restrictive with a large loss across the core , Even cleaning the item wont help much.
It has been test but AutoSpeed
Also please note the flow of an aftermarket unit in the last graph, I would recommended a FMIC and CAI. W\M can come after a turbo upgrade
Posted: Mon Jul 20, 2009 11:42 pm
by aep886
get a vented bonnet and relocate the filter
Posted: Tue Jul 21, 2009 7:21 am
by KCSX
im currently working on a vented head light, will let you'll know how that works out
Posted: Tue Jul 21, 2009 8:04 am
want to go W/M too. seems like a very good mod from what I've heard. but yeah, like PFB said. IC CAI and then turbo and W/M.
Posted: Fri Jul 24, 2009 9:56 pm
by aep886
drive with out the bonnet^^
Posted: Sun Jul 26, 2009 10:47 am
by 300sx
going to open a can of worms here..
in my ever so humble opinion the only benefit to be gained from a cone filter is when the stock paper element can no longer be used due to modifications. a PROPER airflow mod would prolly be to use a airbox and paper element from a bigger capacity motor, thus allowing more airflow to your modded motor. paper elements flow at least as good as cotton filters when clean, and def. filters better..
that said , i also use a massive k&n on my s13, because of space constraints.. no way to fit an airbox anymore.
read this for an interesting perspective..
http://www.bobistheoilguy.com/airfilter/airtest1.htm
