Throttle body selection
The Inlet cam from the DE works but the Exhuast cam is the same as the CA18DET
Anyone got pics of the ports on a 4 port?
I recall the SA version of the sentra 1.8i 16v being critisized cause the 103kw reading was a japanese reading which was actually like 95 or so SA kw.
Nissan SA then did work on the SA versions to get them to 100 SA kw.
So I'm sure our cams and heads must be better.
Even if the heads were identical to DET heads, this one is flowed so it will flow better.
I may part with the DET head though, but will only be in a month or two.
