maybe i must go play solitaire instead before i tell draco his mother is quite nice
Bearings Knocking on heaven's Door
But I thought you were after more power, what did you drop it too??The new HG was ordered to drop compression, just for a little reliability.
My dad says the same thing, if you fiddle it will break (I get this everytime something goes wrong), and he is a mechanic for 30 odd years now."my daddy sed that the highly qualified and clever engineers at the factory designed the cars/engines so that all the little parts work together optimally but you will always have some backyard dudes with 120-piece toolkits from Hyperama and a drill thinking that they can do better"
Dont want to start this arguement again but leave it to the pros. I understand if you cant afford them but if you can send it in to a mechanic to work on (dont mean to be a prick now but how many of the guys here have met this same fate??). I am a qualified mechanic and still I call on my dad for his opinion, why because he is better than me, experiance counts here guys.
He has done alot of flow work, that motor will breathe beautifully, Im jealous.AKA wonderboy...I am sceptic hear, I still ask, how do you make your power if the boost is down, the timing is down and the compression is dropped.....I am sorry but it does not make sence....sometning was doen to make your power and that might have lead to the current situation.
Um Gary....the flow job was done after the power figure he shows, he would make even more now....but still could you make 20kw on the wheels with a flow jobGary57 wrote:He has done alot of flow work, that motor will breathe beautifully, Im jealous.AKA wonderboy...I am sceptic hear, I still ask, how do you make your power if the boost is down, the timing is down and the compression is dropped.....I am sorry but it does not make sence....sometning was doen to make your power and that might have lead to the current situation.
Sokar....
Gary - Cant wait for the Dyno , Will be very interesting . I really interested
Heard its around 7RWKW
And don't get me started on tuners, because thats a big can of worms.
R20-000 rand later and in the shit after someone has touch my car is not where I want to be
I have access to almost 60 years of experience about 40 years being race everything from Rotor to V8's and even they are surprised because they know the amount of time,Money and parts I use.
I have researched every modification made to may car and maximized its return with the next mod.
Boost: 8 Psi (0,55 Bar)
Timing: 12 BTDC
Comp: 8.3 est (Commetic)
148 RWKW was before the cam and other mods....
Timing: 12 BTDC
A.K.A -  Wonderboy
oh i laughed all the way through this ranting and raving.
phinx wanting to sell his sx (is this the same phinx i know!!!).
toby saying that only stock motors dont give shit. (how long did your stock motor last tobles???
gary saying that you should leave to the pro's. (like masturbator???)
widomaker saying that draco's mom is nice (ess good good good ees good ees nice!! (harcore dude - i wouldn't F___K so much with draco - i dont think he was kidding about pissing down your throat!!!).
and saying that fiddling makes things break???(sometimes a good fiddle makes things all better!!!)
sokare - when you find out what boost is, can you explain it to my stoopid engine so that we can be friends again???
and did someone say flowjob - damn i almost misread that.
				Hennie Marais
Problem is I will only be able to tell using my but dyno, cause since the last dyno tune (which is a different dyno to the one I will be using) I have fitted tubular manifold and bigger cooler and I can deffinately feel a BIG improvement. I think at 1Bar it will make more than 7RwKw more like 12RwKw or so, well from what I have read. If I can get close to 190-200RwKw I will be happy, that will be will only bolt on mods.Gary - Cant wait for the Dyno , Will be very interesting . I really interested
190-200RwKw you will be maxing or very close to maxing your injectors for a good part of your upper rev range if you are still using (370cc)
I would Say around 7 Rwkw because, It's a small change in degree and lift but it does give alot more midrange punch so there should be good gains there
A.K.A -  Wonderboy
