Posted: Tue Aug 14, 2007 12:22 pm
TIT SCARAPER.......you are a very sick boy....sick I tell you
https://forum.sxoc.co.za/
Sounds like Phinx & derek are out of this round.Dislex666 wrote:Can we wait for payday to do this? I had another flat tire and i think the rim might be in a bit of pain. So i'm driving around on the spare (When driving)
Will have it fixed next week and then we can go
That's fine, probably will be better in terms of reliability in any wayDislex666 wrote:yup 1 bar - i'm too lazy to mix stuff to get the octane high enough for highboost
what fuel are you running. im using 95 can i also lift boost to 1bar curntly 0.8????Dislex666 wrote:yup 1 bar - i'm too lazy to mix stuff to get the octane high enough for highboost
Dislex runs 1 bar on 95. I have water/meth but its disconnected at the moment so I might tune mine to run without it for now.dwayne wrote:what fuel are you running. im using 95 can i also lift boost to 1bar curntly 0.8????Dislex666 wrote:yup 1 bar - i'm too lazy to mix stuff to get the octane high enough for highboost
From what I've read, one can never make decent power running closed loop... but again only what I've read.qewrty wrote: Running closed loop lamda should also help correcting afr's but I think it its to compensate for other afr factors, not rich/lean fuel, someone know?
I think water/meth does help and in CC's case is enough but I'm sure there are limits, I don't see CC running 1bar boost for instance.Vlade wrote:From what I've read, one can never make decent power running closed loop... but again only what I've read.qewrty wrote: Running closed loop lamda should also help correcting afr's but I think it its to compensate for other afr factors, not rich/lean fuel, someone know?
I'm also not so sure how effective the water/meth is at cooling... Was comparing my air temps to ChemCools the otherday, my intercooler runs about 30deg less, but I can't really say this with confidence since I only saw his air temps once, and our our measuring method / sensor location is also different.
Yes I do run @ 1 bar. 1.3 Bar is the limit for no intercooler fitted. I dont want to go the route of FMIC. I will however upgrade to twin nozzles. One just after the turbo and the other like the current nozzle location in friont of TB. Then I think and I am optimistic that my temps will be similar or close to what Vlade has mentioned. In other words, the second nozzle will hopefully act in place of FMIC. Okies in America do this with great success.think water/meth does help and in CC's case is enough but I'm sure there are limits, I don't see CC running 1bar boost for instance.
If I was CC I'd get a small intercooler to help with cooling, esp 4 the next CA. But then again I guess CC = chemical cooling
For aesthetics I'm keeping my water/meth installed though, might just put 100% water in & use it to spray my intercooler, like an STI.
Other than something like Toluene does any1 have suggestions on fuel additives? Don't say gass
OKChemCool wrote:Yes I do run @ 1 bar. 1.3 Bar is the limit for no intercooler fitted. I dont want to go the route of FMIC. I will however upgrade to twin nozzles. One just after the turbo and the other like the current nozzle location in friont of TB. Then I think and I am optimistic that my temps will be similar or close to what Vlade has mentioned. In other words, the second nozzle will hopefully act in place of FMIC. Okies in America do this with great success.think water/meth does help and in CC's case is enough but I'm sure there are limits, I don't see CC running 1bar boost for instance.
