Project - Damn CA
Hennie Marais
Hennie Marais
Hennie Marais
**** Update****
Hi guys here are some updated pictures of the R&D fitment.
Intake Removed
Test Fits
Blurry Pic of the Port
Problem Area's
The Water line running under the intake need to be re-routed
Quick question to all the guys on the fourm there is a Pipe leading from the thermostat intake manifold (Pic 1) under the old intake to copper hard line under the intake (pic 2) .
Can this Pipe be removed and If not why?
I know it could be a water cycle but my thermostat says partially open so can it be discarded
Thankz
(Pic 1)
(Pic 2)
Intake Removed
Test Fits
Problem Area's
Thankz
(Pic 1)
(Pic 2)
i'll go have a good look at it in the morning, but i think the copper pipe feeds the turbo - so dont remove that.
as for the smaller pipe - not sure now - but i will return soon with an answer.
oh ja - i think that manifold is hotcakes!
my order will be in soon!
you think it can be made so that it gives more low down torque than the stock manifold??? i dont want top end, cos i need lots of power from as early as possible - and i dont want to make my sx a turbodiesel!!!
