Page 2 of 3
Re: Help!!
Posted: Mon Jan 30, 2012 11:07 am
cool.
Re: Help!!
Posted: Mon Jan 30, 2012 12:06 pm
by Grant222
Whats the best plug in procedure? Start the car then plug in or plug in then start?
Re: Help!!
Posted: Mon Jan 30, 2012 1:51 pm
plug in then start although it should not hurt doing it the other way around...
Re: Help!!
Posted: Mon Jan 30, 2012 2:40 pm
by Grant222
Ok so with the friewire update its a lot better, but after a minute or so it freezes the whole time and i have to close it, then it says comm error and wont pick up
Re: Help!!
Posted: Mon Jan 30, 2012 3:21 pm
That is speed on the com port...it's either to slow or to fast...
Re: Help!!
Posted: Mon Jan 30, 2012 3:51 pm
by Grant222
How would you know if its to slow or fast?
Re: Help!!
Posted: Mon Jan 30, 2012 3:56 pm
You have to go into the com port adjustment under settings, amin and adjust it there...you have to keep doing it till you get a good speed...lower is normally better.
Re: Help!!
Posted: Mon Jan 30, 2012 4:12 pm
by Grant222
I just found your post on SNS, so the RS232 to USB is fine? I dont need a com to com cable?
Re: Help!!
Posted: Mon Jan 30, 2012 4:23 pm
by Grant222
Settings are 9600bits per sec, 8 data bits, parity none, stop bits 1, flow control none
Re: Help!!
Posted: Mon Jan 30, 2012 4:28 pm
Check what the bit rate is on the mr. turbo, then mach that and the rate on the port
Re: Help!!
Posted: Mon Jan 30, 2012 4:44 pm
by Grant222
Ok thats going to be hard to find but will look, does it matter if im using windows 7?
Re: Help!!
Posted: Mon Jan 30, 2012 5:15 pm
wat i find wierd is when you turn you lights on it dies wtf???? wierd
Re: Help!!
Posted: Mon Jan 30, 2012 5:23 pm
by NIZAN-R
weak altinator low voltage to ecu?
Re: Help!!
Posted: Mon Jan 30, 2012 5:28 pm
i was thinking that but there would be a problem with starting then
Re: Help!!
Posted: Mon Jan 30, 2012 5:48 pm
by Grant222
We thought it might be the batt or the altinator, the batt was not charging, put in new(used batt lying around), it was charging and seemed better, would idle okish and sometimes die, so i have no clue whats up, could it be the altinator? how would i test
