Help!!
Re: Help!!
cool.
Grant222
Engine: 2JZ
Real Name: Grant Jones
Re: Help!!
Post by Grant222 »
Whats the best plug in procedure? Start the car then plug in or plug in then start?
Re: Help!!
plug in then start although it should not hurt doing it the other way around...
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Ok so with the friewire update its a lot better, but after a minute or so it freezes the whole time and i have to close it, then it says comm error and wont pick up
Re: Help!!
That is speed on the com port...it's either to slow or to fast...
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
How would you know if its to slow or fast?
Re: Help!!
You have to go into the com port adjustment under settings, amin and adjust it there...you have to keep doing it till you get a good speed...lower is normally better.
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
I just found your post on SNS, so the RS232 to USB is fine? I dont need a com to com cable?
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Settings are 9600bits per sec, 8 data bits, parity none, stop bits 1, flow control none
Re: Help!!
Check what the bit rate is on the mr. turbo, then mach that and the rate on the port
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
Ok thats going to be hard to find but will look, does it matter if im using windows 7?
Re: Help!!
wat i find wierd is when you turn you lights on it dies wtf???? wierd
NIZAN-R
Real Name: Renier
Re: Help!!
Post by NIZAN-R »
weak altinator low voltage to ecu?
Re: Help!!
i was thinking that but there would be a problem with starting then
Grant222
Engine: 2JZ
Re: Help!!
Post by Grant222 »
We thought it might be the batt or the altinator, the batt was not charging, put in new(used batt lying around), it was charging and seemed better, would idle okish and sometimes die, so i have no clue whats up, could it be the altinator? how would i test
