Lol I knew that might be a bigger topic when posting that picpoizen wrote:Nice super bright yellow crocs you sunglasses on
S14 Stalling
Thanks guy! I know of someone with spare coil packs will check it out! okie dokie lets see the coils first and see if it helps.phoenix s14 wrote:Coilpack will missfire badly like that. As a cheap fix you can try resealing it with silicone gasket. Had a similar problem on my friend's car. Because he has to drive it everyday we resealed it with silicone and then schrunk some sleeving around it. it stopped the missfire but he replaced it eventually.![]()
On the point of the TPS - you need to check the resistance between the pins. on a SR it is between pin B and C. and I think it has to be 0.7k or something. Am sure someone can help you with details on how to check it.
Red S14
