RB25DET s13 help
Tobie
Post by Tobie »
Hi, one of my dicktator triple igniters stopped working on my RB25, had the same symptoms as you described.
Heat.... does your RB breathe excessively by any chance?
400m = 11.9sec @ 187km/h @ Midvaal
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks rat, ljs14
@tobie, i dont think so i dont notice anything from the breather system.could it be something from the breather system that i cant see or hear?
Current. CA18DET S13
Skylinefreak
Post by Skylinefreak »
nirvash wrote:@tobie, i dont think so i dont notice anything from the breather system.could it be something from the breather system that i cant see or hear?
His RB25 had a bit of heat issues and breathed a bit, when we opened it up we got a sad sight... Couple of fried pistons.
RudeBoy
Post by RudeBoy »
sure it was white smoke , not steam? sounds like it could be head gasket
specially if its been over heating
irridiums will foul even faster than normal plugs, waste of time and money
rather get ngk bcpr6"or"7et
RudeBoy
Post by RudeBoy »
Tobie wrote:Hi, one of my dicktator triple igniters stopped working on my RB25, had the same symptoms as you described.
his car doesnt use dicktator ignitors - coils have built in ignitors
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks rudeboy.that could possibly be it, the hg, how can you tell though without taking the head of?
trying to sort everything out, so have a new oem water pump on the way as well, hope i dont need to add a hg to that...
also ya the series 2 RB25DETs have built in igniters into the coils
djtreble
Post by djtreble »
nirvash wrote:thanks rudeboy.that could possibly be it, the hg, how can you tell though without taking the head of?
Check for water in the oil and/or oil in the water (mayo type substance under the filler caps)
www.rotawheels.co.za
www.kaihatsu.co.za
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
will have a look, thanks.
Guy
Post by Guy »
A pressure test on the cooling system will also tell you if the headgasket has gone.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks, will look into that.
