Page 2 of 2
Posted: Mon Nov 01, 2010 12:58 pm
by djtreble
If you have an anti lock light and it's illuminated then the car use to have ABS and it has been removed.
To get rid of the light, remove the ABS computer. It's behind the interior trim in the rear passenger quarter (passenger side)
If that doesn't work (which it should), remove the light in the dash for the abs
Posted: Mon Nov 01, 2010 1:33 pm
I think you should just have to bridge two pins on the pumps connectors once you've removed it. Ill check and post what I've found.
