Page 2 of 2
Posted: Tue Mar 06, 2007 1:59 pm
by Daniel
johansx wrote:What does the spark plus look like after a short run? Soot, lots of carbon or clean?
they where clean the first time i pulled them. Going to check again in the week now that i have more km on them
Posted: Tue Mar 06, 2007 7:59 pm
by ChemCool
Daniel, you know of course that I follow these threads very carefully? Why, because my sx is doing the same since a week ago. Great balls of white smoke during decompression, sort of smoke during acceleration and also smokinf badly during idling. And if I touch the feul pedal slightly during idling, it also smokes like hell. I can smell the oil burning. One other thing though - I dont get the boost up to 1 Bar. 0.5 the most!!!!!
Some members tell me it is turbo seals, and then we get the answers on valvestemseals etc. I need to do compression test, remove turbo geuso meter with other to check boost. To check sparkplugs.
So you slightly in front with the problem solving.
Posted: Tue Mar 06, 2007 8:12 pm
by The Calibrator
Cylinder leakage test=
pump compressed air into cyl while at tdc. Air runs through a gauge which shows you a percentage pressure loss.
Anything over 20% leak is poked you can also listen at the intake and exhaust for air leaks past the valves.
If there is plenty air coming out of the breather with no intake or exh leaks then the rings are shot.
Posted: Wed Mar 07, 2007 9:29 am
by Daniel
Thanks Calibrator
Freddie i dont get smoke on idle at all, or perhaps not yet anyway
Anybody know where i can buy or borrow a Cylinder leakage tester
Posted: Wed Mar 07, 2007 9:57 am
its not cheap hey... expect to fork out above R500... Last one I saw was over a R2000 but it was as Snap-On item. And you'll need a compressor.
Posted: Wed Mar 07, 2007 6:53 pm
by The Calibrator
I have a Snap On one
Posted: Wed Mar 07, 2007 7:51 pm
by widowmaker
i have compressor
Posted: Wed Mar 07, 2007 9:24 pm
by The Calibrator
I have a snap on one, a compressor and a oscillosope
Posted: Thu Mar 08, 2007 7:14 am
by widowmaker
hehehe, was expecting a reply like that
its like throwing a stone into a cave to see what comes out
Posted: Thu Mar 08, 2007 10:44 am
The Calibrator wrote:I have a snap on one, a compressor and a oscillosope
i have a strap on one too. whats the other stuff used for???
Posted: Thu Mar 08, 2007 12:07 pm
To pump you car full of shit and then listen to it squeeling.
