CA20DET vs SR20DET
What ecu are you using now? I can check how to get the air con running without a ecu at all. If you want?
cursed_s13
Post by cursed_s13 »
@Charlvdw
When I bought the car with the motor in it, it was running on a Gotech. Then the headgasket blew. Then I removed the motor and got myself the standard CA18 and connected the gotech to the standard motor. Was struggling with places to tune the ecu and then eventually Turbo Toys/Boys (something like that) in Krugersdorp blew the standard turbo en came to the conclusion the ecu was faulty. Then I got myself the turbo from an RB25 and also installed a Dictator...
So I am now running A Dictator. I'd like to use the standard CA18DET ecu and it is stil in my car but I dont know if the ecu is working and I also need the standard harnas and airflow meter that I dont have.
cursed_s13 wrote:@Charlvdw
How did you mount the rb turbo , did you build a mani for it?
cursed_s13
Well the mani that was on the CA20 with the T4 was just by luck the same for the RB turbo, it was a direct fit. :D
cursed_s13 wrote:Well the mani that was on the CA20 with the T4 was just by luck the same for the RB turbo, it was a direct fit. :D
Lucky bastird! :D Ill check the air con pin out for you tonight, you still have the std ecu plug in the car?
cursed_s13
LOL jip the std plugs is stil in the ecu but on some places the harnas is cut and incomplete :(
cursed_s13
If anyone knows of internals for the CA20 please let me know!!! :lol:
