Posted: Fri Feb 16, 2007 11:36 am
Thanx amilion
veecee il give it a try later this afternoon . THATS a bad one for u widowmaker
https://forum.sxoc.co.za/
Another fact: One headlight will always stop before the other. Which in turn means one headlight will be at different heights regardless of when you decided to press the button again.veecee wrote:ok - if i remember this correctly... here goes...
1. get in car armed with wire cutters
2. locate button that opens and closes lights without turning them on.
(its the top one on the right i think in our cars)
3. pry it out of its socket
4. have a close look at the wires behind the switch (should be about 6+-1)
5. locate the brown wire
6. cut it
7. put the switch/button back
8. turn on lights
9.press modified button in
10. turn off lights
11. press modified button twice quickly - like double clicking a mouse.
12. do it over and over to get desired height!!!
fact (for my sx at least) - if you follow steps from 7 onwards, that is without cutting the brown wire, the headlights will wink (go up and down) alternatively. first one side then the other. thats if you do the double clicking quickly!!!
the knobbies work if they are connected.widowmaker wrote:IIRC you first have to unplug the lights from the bottom, otherwise them knobbies do nothin
sleepy eyes good, but i prefer ANGRY EYES
Ja I know it resets itself. so you have to do it again....veecee wrote:now go turn on your lights, then turn them off again.
what happens?
