Digital non contact infrared thermometer
- Charlvdw
Wouldnt mind a fluke but its not.
Non-contact accurate temperature measuring
Built-in laser aiming
White backlight liquid crystal display
Distance spot ratio: D:S = 12 : 1
°C / °F selectable
MAX., MIN., AVG and storage functions
Extensive industrial usage : food, security, inspection, train. diesel engine, injection molding applications, and etc.
Resolution : 0.2°C or 0.5°F
Temperature range : -13°F to 1040°F (-25°C to 560°C)
Sampling rate : about 0.5 seconds
Spectrum reaction : 6 -14μm
Emissivity : selectable of 0.99, 0.95, 0.89, 0.85, 0.79 or 0.75
Power : 1 x 9V Alkaline battery (Included)
Supplied with a carrying pouch
Accuracy:
-25°C to -10°C (±3°C) -13°F to 14°F (±5°F)
-10°C to 30°C (±3°C) 14°F to 86°F (±4°F)
30°C to 560°C (1.5% ±1°C) 86°F to 1040°F (2% ± 2°F)
Operating environment temperature : 32°F to 122°F (0°C to 50°C)
Item Weight : about 195g (battery included)
Item dimension : 180 x 48 x 96 mm (7.09' x 1.89' x 3.78' inch)
°C / °F selectable
Accuracy:
- Drillergy
- Real Name: Darryl
lol dont spill the tea but I think he's saying yes.Charlvdw wrote:So in the queens f*cking english you are saying its not to kak?original wrote:well there you have it!!!!!! Emissivity : selectable of 0.99, 0.95, 0.89, 0.85, 0.79 or 0.75
the 0.95 will work very well!!! Will be out by like 0.775 of a degree which is absolutly nothing
- Drillergy
- Real Name: Darryl
If you flash a chick with this magic stick, would it tell you if shes hot or not???Charlvdw wrote:Now you see the whole point is non contact so i just have to point it at my ear no need top stick anything in anywhere.veecee wrote:screw you guys - you cant go re-hijacking my thread!!!![]()
yeah charl - before you get hot under the collar, maybe stick that thermometer in your ear???
- rat
- Real Name: Rat
so how much for this againDrillergy wrote:If you flash a chick with this magic stick, would it tell you if shes hot or not???Charlvdw wrote:Now you see the whole point is non contact so i just have to point it at my ear no need top stick anything in anywhere.veecee wrote:screw you guys - you cant go re-hijacking my thread!!!![]()
alright - go point it at your bum then! should give you practice for when the kiddies arrive...Charlvdw wrote:Now you see the whole point is non contact so i just have to point it at my ear no need top stick anything in anywhere.veecee wrote:screw you guys - you cant go re-hijacking my thread!!!![]()
hang on... am i thinking of draco?
- rat
- Real Name: Rat
first time ever but no pics pleaseDrillergy wrote:Would you be able to accurately determine at what temp do women get nipples stand?
This would give me an indication of what temp. to set our reception aircon on.
And pls Charl dont do this test on yourself and post the results....
