2JZ S13 ...THE Second Coming....more power
Im tired of bull shit storys,,,
Should have bought it to me...
RBSX
1.0 Bar Boost
Post by RBSX »
Oh small update
Ive been working every nights with the 1st 2jz sx i got
new pump and seal is in, but while working under , i wasnt happy with the wiring protection getting melted so i re routed everything away from the turbo manifold side, moved the fuse box, Alot of time and effort
double checked every nut and bolt
Will start it up this weekend, hopefully she hold the seal
What i was really impressed about was the sump, it was clean no sludge at all, everything looks really clean, think i may have a really good engine
will post a vid on start up
Good to hear....hope it all goes well!!!!
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
Good luck ,
I cant believe you getting @#cked around AGAIN :shock:
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
RBSX
1.0 Bar Boost
Post by RBSX »
oh sorry if i confused anyone
this is the first sx i built with andre, Its been lying in storage for a couple of months, sold it to a buddy and now things went sour. so i got it back
as for the second one which is Riaans Project, as usaual Andre takes about 6months to finish
apparently the engine is in but , no pics yet
GREAT NEWS, IT STARTED UP, AND Idling SMooth
Tomorrow i install the screamer pipe, as Andre Messed up and did not fit
any thing to the wastegate, its just open,
going to have to make a pipe up and fit it
Then i drive it and i pray that the seal holds
RBSX
1.0 Bar Boost
Post by RBSX »
Okay so its been a while , been really busy
Lets just say everything failed
I finanly gave it to gary, and he managed to sort the seal problem out, not sure how he did it but it worked, i have dropped the rev limit to 6000rpm
as gary says my injectors ar maxing out somewhere there at 0.8 bar
so im not sure what will happen at 7500rpm as Andre reckons they pop at 7500rpm.. but thats were i should be reving with that big ass turbo
i still dont feel its fast, its gota a truck load of off boost torque, when it gets into boost its like a m3,,its linear, no sudden whiplash, just acceleration and screaming and a hiding 2 any 4pipe m3 around
Its been a couple of weeks now its been reliable, drove it to work and around durbs for a week, its liter than my 540 on fuel so i thinks its about 12l/100kms off boost....lol
still have a few plans to make the engine bay look nicer, mainly that horrid tappet cover
Ive taken the bumpers and wheels of the car in jhb and put them on this one, as that one will be the animal and deserves the kit
had to try an temp fix the holes Rian cut in,
heres some pics
RBSX
1.0 Bar Boost
Post by RBSX »
RBSX
1.0 Bar Boost
Post by RBSX »
i had the kit bumpers on but ive swop them with the car in JHB
ill try to keep this car as stock looking as possible, they need to be painted
again, as they dont match the white on this car, also need to paint the bootlid
looking better after puting the stock bumpers on proply and some 17" wheels, they are way to small for the car 205/40/17
but the grip was slighly better
still need to bring down the fender pieces, looks crap without them
RBSX
1.0 Bar Boost
Post by RBSX »
i hate those big holes in the from bumper, they look kak
any ideas guys, i put in some mesh, but still looks kak
I go through gears very quickly and fifth feels like fourth, i think my ratios are out. so im gona try 18" wheels to see if that makes any diff
im using the r154 gbox, does anyone know if the ratios, are not suitable for the 13 diff or not
Hennie had a set for sale, they not the best looking, but dam the tires are worth if, Goodyears,, like new
will put them on this weekend
next up is a set of lower and stiffer springs, anyone got some for sale
heres a small vid, will get someone ro help make a decent one
RBSX
1.0 Bar Boost
Post by RBSX »
Gary has driven the car alot,,, so if you wanna know what it feels like ask him, it would be nice to compare to rats Rb25 when he is done, as that was the route i would have went, but it worked out cheaper going the 2jz
gota say parts are so much cheaper and more available, all you need is the part number go to toyota dealership and the guy will order it
I paid R1650 for a new oil pump from toyota
As for the other SX.... andre is really something else,,, should be finished in 6 months
will have to see but remember you had the RB26. Mine will be running the std turbo so will have little lag but not as much top end as your beast
RBSX
1.0 Bar Boost
Post by RBSX »
RAT: so when are you starting with the conversion
i almsot went Rb25 beacuse i couldnt find another Rb26, and at that time i couldnt find a Rb25 for less that R14k, and the 2jz was 13k, i know its sounds silly leaving a Rb25 becasue it was R1000 more, but i was looking for the most power i could get on a stock engine, and after some quick resarch and plenty fone calls, 2jz seems liked the better option, if you dont mind driving a Nisota, or toysan
but it will be nice to see how your setup runs against mine
RBSX
1.0 Bar Boost
Post by RBSX »
so i fitted the wheels today, im not a fan of the design, but it will do, the tires are hot.. goodyear eagle f1, hope they offer more traction
Image[/img]
Started already, check my project
Re: 2JZ S13 ...THE Second Coming....more power
aNY MORE UPDATES ON THIS PROJECT ??
