Page 2 of 3
Posted: Mon Aug 25, 2008 12:03 pm
by The Calibrator
Step 1 is to check the plugs if they look decent close the gaps up you may need to go as small as .50mm in some cases. If closing the gaps up helps then start looking for some coils with horsepower so you can run bigger plug gaps again.
You will find that as you close the gaps up the idle will start to deteriote
Posted: Mon Aug 25, 2008 8:53 pm
:shock: :shock: :shock:
Posted: Mon Aug 25, 2008 8:56 pm
by mario_200sx
veecee wrote::shock: :shock: :shock:
:lol: :lol: :lol: :lol:
I know! :wink:
Posted: Tue Aug 26, 2008 10:15 pm
by RudeBoy
does the wolf have a boost cut setting like the microtech??
Posted: Wed Aug 27, 2008 8:26 am
YIP.
Posted: Wed Aug 27, 2008 9:01 am
by RudeBoy
and? what it set to? cause it sounds like what my kadett was doing on boost cut..
Posted: Wed Aug 27, 2008 9:24 am
I would check the plugs first. I had the same issue with mine, it was over fueling and was fouling the plugs then you when you floored it it would break down. Closed the plug gaps and changed from BCPR7ES to BCPR6ES and it sorted it out untill I could fix the fuel map. When the fuel map is correct you can change back to BCPR7ES.
Posted: Wed Aug 27, 2008 9:46 am
by RudeBoy
Agreed, if the fuel map is a f-up you going to battle, have it not been set up with a wideband yet? also the BCPR7ET's work better...
Posted: Wed Aug 27, 2008 10:20 am
I would rather go with a hotter plug 6 vs 7, this will help prevent the plugs fouling.
Posted: Wed Aug 27, 2008 2:09 pm
by RudeBoy
thats curing the symptom not the problem, why are they fouling? why not fix the fuel map?
Posted: Wed Aug 27, 2008 2:16 pm
you need it to run properly while you are fixing the problem dont you???
Posted: Wed Aug 27, 2008 2:32 pm
Correct but it is not easy to fix the fuel map why the plugs are constantly fouling. Thats why I say fix #6's then sort the fuel map out. When right you can change back to 7s.
Posted: Wed Aug 27, 2008 11:56 pm
wow... been MIA for a few days... some action on my post, makes me wanna go work on the car right now... :D
Plugs is the first thing I'll check tomorrow morning...
Ja this is one of this funny things, car runs like a dream for weeks then suddenly this...
Love the have a look at my AFR but don't have something to connect to the Wolf, dont have a Serial 2 USB nor a laptop... will maybe drive to someone that have one of those things tomorrow, might even be a sensor that F'd out and causing the car to overfuel... not unlikely...
Posted: Tue Sep 02, 2008 3:19 pm
Looks like its gone from bad to worse... now the car can't even pick up revs... but idles perfectly.
Posted: Tue Sep 02, 2008 3:53 pm
Plugs??
