means that a specific cars suspension gets designed with a wheel with a certain offset in mind (designers choice) .. affects track amongst other things
you can go positive or negative offset using a different magwheel for instance, but stray too far from what the suspension was designed for and you could end up with adverse/unpredictable handling.. abnormal tyre wear.. tyres touching wheelarches ,ect..
sorry, dont quite know how to explain better than this, maybe someone else can give a bit clearer explanation?
300sx wrote:but stray too far from what the suspension was designed for and you could end up with adverse/unpredictable handling.. abnormal tyre wear.. tyres touching wheelarches ,ect..
Thats the mild stuff, worst case you can destroy your wheelbearings, last time we priced they were just under R2k EACH from nissan, and you cant get anywhere else.
