Throttle body selection
i reckon. specially if its the throttle body thing, on that piece of cast aluminum that the fuel rail bolts to...
because if you aren't happy with the power, then you can swap heads from your two motors and you will be able to bolt the throttles onto the 4 port head.
then you should definintely be able to make the power you're after!
In that case there is some extra power....are you sure that head fits straight on the block and obviously the det inlet and outlet manifold bolt straight on that head....Gary57 wrote:The DE head is common mod for teh DET block, they flow more than the DET do.
then again it should because we use the CA18DE gasget set....
Sorry to cause Cr@p here but I really don’t think the DE head will flow anymore then the DET.
It just sounds strange to me, because why would Nissan have two different casting numbers for the 4 port Heads on the CA18DE and CA18DET and if so then I would suspect the DET head has been made stronger to take the punishment of boost by having material added, maybe around the ports or so on.
The Only real mass producing manufacturer I know that will change/modify there heads for the same Engine is Honda and that’s for the Type R range
Whats the casting mark numbers on the heads?
But Who knows maybe Im wrong
