between yourself today G and Daniel yesterday i've nearly wet myself twice laughing!!!
hehehehe - chrome mags suck balls... indeed!!!! (draco's gonna be so pissed!!!! hehehehe)
and widowmaker - having teeth out is not funny business... its a serious affair. and medical aids like discovery dont pay because they think that removing 5 front teeth is cosmetic. they must have lots of capetonians as customers!!!!
it will also make your engine run crappy. kinda like babies when they're teething - they run crappy too. but i once was out a tooth on the exhaust side and nothing broke!!!
so dont stress too much - just stop being lazy and go check!!!
Like they sai timing is very important one tooth out and u wont get vokol out of the car for the amount of teeth im not shure but the best way to check is to turn the timing belt inside out hold the two together (new and old one ) mark them both at the same place and rotate them at the same time with the teeth meshing into each other
200SX MP wrote:Like they sai timing is very important one tooth out and u wont get vokol out of the car for the amount of teeth im not shure but the best way to check is to turn the timing belt inside out hold the two together (new and old one ) mark them both at the same place and rotate them at the same time with the teeth meshing into each other
You lost me there middelburg petrol(Theoniel)
Since Sokar informed me that I don't know what boost is and Widowraper hitting on my mom I am totally confused.....I am now dowting everything I ever thaught I knew about anything......
Lets try this again and slowly this time u take the 2 timing belts right turn them inside out with the teeth on the out side right but them against each other like 2 gears right mark both at the same place right then like 2 gears rotate them with the teeth mashing into each other if the marks correspond the 2 belts are the same size HAVE U GOT IT NOW en jy het all my inerlike simpati met widdowraper
200SX MP wrote:Lets try this again and slowly this time u take the 2 timing belts right turn them inside out with the teeth on the out side right but them against each other like 2 gears right mark both at the same place right then like 2 gears rotate them with the teeth mashing into each other if the marks correspond the 2 belts are the same size HAVE U GOT IT NOW en jy het all my inerlike simpati met widdowraper
Ok maar hoe se dit of jou cams n' tand geslip het of nie....
it is ok to mock chrome mags, red sx's, english people, methanol and dunlop, but 14 people have been banned after taking the WHITE SX in vain.
BY CHUCK NORRIS AKA MURPHY (oh shit i swore i would never reveal)
now i forgot what i wanted to say in the first place - there's someone ringing my doorbell - BRB
