Parts?
ggg thanks for tha suport
  i went trough a corner that is very slipry touched the white line and liped into the pavement. the pannelbeter quoted me R68000!!! the only part of the car that is damaged is the parts mentioned. the body nothing only the lip is scrartche and cost R150 to fix
							GOING SOME WHERE FAST!!!!!!!
						Sorry Dude....
There is an S-14 (front smash) being striped for spare in PTA.
The place is called Toysan...
Vom Hagen St
pretoria West
pretoria
0183
phone Phone012 3276887
And they are damn expensive, but maybe better then nissan
Vom Hagen St
pretoria West
pretoria
0183
A.K.A -  Wonderboy
those other parts i mentioned are much cheaper than 68 grand, even if you pay in pounds and include shipping!!!
you can get all the adjustable suspension arms with rose joints too!!! i think i remember seeing the control arms for 400 odd dollars (US). thats about 3 grand for a set. even if you spend 30 grand, you still get hot modded suspension, and pay half the panelbeaters quote, and you can install them yourself!!!
the bearings and axles are a different story. the bearings i would get new from nissan, and the axles i would find used (but probably overseas).
now stop being a knob and leave the drifting to the track!!!!
LOL - good luck anyway!
- Drillergy
 - Real Name: Darryl
Yea, well I did the body work on my car. Drifted into the centre island and painted my car yellow on the side with a robot, luckily it was just a scrape.
Anyways, most S13's do not have LSD's....
Is this true...
To identify if it does, someone told me you need to look for an orange sticker at the back suspension....
Is this true????
Is this true...
Is this true????
actually most do. SA ones anyway!!! they were fitted with a factory viscous LSD. not the best, but way better than nothing!Drillergy wrote:Yea, well I did the body work on my car. Drifted into the centre island and painted my car yellow on the side with a robot, luckily it was just a scrape.
Is this true...
Is this true????
yes you can look for an orance sticker on the diff somewhere. i think its on top.
or you can do the test. jack both rear wheels off the floor. turn one wheel, if the other turns in the same direction then its LSD. if it turns in the other direction then it isnt LSD.
simple hey!
as far as I know all RS13's have an LSD standard,Drillergy wrote:Yea, well I did the body work on my car. Drifted into the centre island and painted my car yellow on the side with a robot, luckily it was just a scrape.
Is this true...
Is this true????
Are you sure that works?? The LSD cant be that sensitive, can it??if the other turns in the same direction then its LSD. if it turns in the other direction then it isnt LSD.
I jack the rear of the car up put in first gear on drive it on idle then try stop one wheel, if you get thrown to the front of the car the it is LSD if the wheel stops then its not.
I know if you dont put the correct oil in the diff the visous packs up and so does the LS, the oil you can only get from agents and they will fill it (wont sell it over the counter).
Had 2 sx's in now that the LSD doesnt work and it is because they used normal gearbox oil.
you could do it gary's way but it sounds awfully dangerous!!! or you could do it my way. its up to you!Gary57 wrote:Are you sure that works?? The LSD cant be that sensitive, can it??if the other turns in the same direction then its LSD. if it turns in the other direction then it isnt LSD.
as for oil, you get oil from spares places specifically for visous and clutch plate type LSD's. its about R115.00 per litre. seems to work fine in my car!
email them to me I'll upload them for you.Drillergy wrote:Ill check with the agents today, see what they have to say...
Oh, ja Im trying to bring in some lights for the 200sx tail lights to be specific...
If I bring it would you guys buy from me?Somewhere between R 2000-
R 2500
I dont know how to put the pic on the site.... please advise.....?
[/img]
