Lotus 7 bits and pieces wanted.
This is creepy, I feel EXACTLY the same way, ask VC I had this exact conversation with him on Monday!Gary57 wrote:What motor do you think would go well in a locost?? I want it to be carb/ side draught. I dont want electrics and shit that can go wrong.
I think the ONLY choice is 4age carbed 16v (for a start) Very simple, spares are a dime a dozen, they never break and the performance options are endless!
Also, once you have the 4age in and running and you feel you need more power (Eventually gonna happen) then you just drop in a 4agze with a turbo and arrange management
Captain Slow to the rescue!
A rotary would also be very nice I love the light engine in a light chassis idea, dunno about turboing it though alot of the builds I've seen they leave it off, less complication.veecee wrote:13bt = R3500.00Gary57 wrote:Rotory motor are expensive arent they??
13btt = R4500.00
quite cheap for many many easily revving kilowatts!
Hennie Marais
Gary, a Toyota engine, LOL, I've got a new best buddy. LOL.
If you go with the 4age then you can either use the T50 box that came of the AE86 toyota or get the standard T50 box and buy an aftermarket belhousing. A custom bellhousing for the W series gearboxes are also available. Go for the 20V, with the light weight lotus it'll fark-off.
Hennie Marais
buy the 13bt for 3500.00
remove the turbo and sell it for R1000.00 at least (its a big turbo).
stick a 48 downdraught on there, and get yourself like 180wkw's!!!
plus you can get the older distributor, and then you wont need management at all.
another bigger toyota option is the 3sge or 3sgte, these are awesome motors!!!
top secret removed the 2JZ-gte and installed a 3s-gte in their supra for the top speed machine - i think it was the top speed machine!!!
hehehehehe - i see you guys should do some more engine options reading???
Hennie Marais
Hennie Marais
LOL, ye that'll sound awesome with the rotary, but then it's not a Lotus, the lutus needs that carb/sidie "snork".veecee wrote:buy the 13bt for 3500.00
3S's are cool, just heavy but they run lekker N/A, only problem, parts are expensive.
4A parts you can buy at ANY parts shop, might even get at the Cafe. hehehe. The 20V might be a little bit more expensive to rebuild.
LOL - i've always said thats a good point for the vw citigolf. if you happen to break down in the desert, and you stumble across a conercafe, they may have a spare block or rings, or whatever under the counter!!!Hennie Marais wrote:LOL, ye that'll sound awesome with the rotary, but then it's not a Lotus, the lutus needs that carb/sidie "snork".veecee wrote:buy the 13bt for 3500.00
