Re: SOLVED! Boost levels eratic on boost tap controller
Posted: Wed Apr 01, 2015 3:07 am
Hi. Pls can you provide me with contact details for excell. I'm experiencing similar problems with boost spikes while cold.troopiec wrote:well great news! my problem is fixed, after alot of research and discussions with a few tuners the next item for inspection was the wastegate (excell 38mm) which i bought second hand in very good physical appearance and was told that it was used for a week and never opened, well i took his word for it at the time and never suspected it to be a problem until my one wastegate stud snapped off and i thought while it was off let me send it in to excell for a service, heres what they found:
home made grinded spring fitted which was completely wrong size in diameter aswell making the piston move skew:
and here you see that the wastegate seals were greased which apparently causes the seals and piston not to work correctly as according to excell they are special seals which are made to operate dry.
so after R550 for new spring, serice, machining, seals etc etc, i put the wastegate back on and shes holding boost steady hot and coldno more eratic boost creep or boost drop, so happy
Thanks
D
