R32/Z32 front brake swop.
actually - without sounding like a ponce...johansx wrote:Caliper needs to attach to the hub...
the calipers attach to the spindle/knuckle, and the wheel and the brake disc attach to the hub.
the hub is the rotating bit!
- johansx
veecee wrote:actually - without sounding like a ponce...johansx wrote:Caliper needs to attach to the hub...
Sorry...
Disc attach to hub... Will the disc attach to the hub?
no the pcd's wont be right. most of the described discs are 5 stud!Gary57 wrote:Ja I meant disc to hub. Will the PCD's be right??
but i'm still investigating whether i can get the discs before the hole pattern has been drilled in!
will let you guys know!
