Noise Problem
going over the engine while it is out of the car is definitely the easiest, but it often isnt as useful as having it in the car.
once its on a bench, you cannot really simulate the conditions that caused the problem in the first place. so unless the problem is "in your face" visible, you may not find it.
BUT - having the engine out of the engine bay gives you the perfect opportunity to replace necessary items, such as water pump and oil pump. please dont rebuild without replacing those. also it gives you the chance to replace little things that perish over time, like hoses. and you can clean out the steel crankcase breather pipe, as those often get clogged and blocked!
- S13- S14 Conversion
When yours made that krrrr, did it also start making the noise when it pick up revs and stay quite when it is below 2000rpm?ChemCool wrote:Yes,spot on, like I am doing--- because it is krrrrr... like wasgoed pennetjie yes.Bearings!!!Dont tell me about krrssss....and in the end he had to rebuild his engine...
200SX S13 converted with SR20DET engine and bigger front intercooler.
0.4bar boost & 140Kw
Where would that breather pipe be:?: I don't know about itveecee wrote:going over the engine while it is out of the car is definitely the easiest, but it often isnt as useful as having it in the car.
it runs from near your water-based oil heater, goes over the knock sensor and bends upwards to end in a vertical orientation. its underneath the intake manifold.S13- S14 Conversion wrote:Where would that breather pipe be:?: I don't know about itveecee wrote:going over the engine while it is out of the car is definitely the easiest, but it often isnt as useful as having it in the car.
yeah my car sounds like a friggin tiger ready to unleash itself on the streets when its cold!!!Gary57 wrote:You thinking right. Piston slap is louder when the motor is cold because the piston is smaller when cold.
but i heard they making new pistons with little ball bearing in the skirts to even out the pistons travel!!! not sure about it though, just a rumour so far!
I'm gonna get Arias forged pistons though, is that also good? Where did you buy the CP pistons and how much were they?Vlade wrote:of you buy CP pistons like me which doesn't really have much pistons slap... Forgies without the slap
a more important question is "how long did they take to get to SA?"S13- S14 Conversion wrote:I'm gonna get Arias forged pistons though, is that also good? Where did you buy the CP pistons and how much were they?Vlade wrote:of you buy CP pistons like me which doesn't really have much pistons slap... Forgies without the slap
Probably because he had to bore the engine and they had to custom make his Pistons, I thinkveecee wrote:a more important question is "how long did they take to get to SA?"S13- S14 Conversion wrote:I'm gonna get Arias forged pistons though, is that also good? Where did you buy the CP pistons and how much were they?Vlade wrote:of you buy CP pistons like me which doesn't really have much pistons slap... Forgies without the slap
