Project - Damn CA
More... I stll havnt added the Gasket-set, waterpump, Cam-belt other belts, tensoners ... ect
add about R 1000 extra plus I still have to pay Hennie for his work
Estimated this rebuild cost me R 15000 +
But I am getting some good power/ reliablity mods for my cash.
Ported head
Cams
Forged Pistons
Balanced Bottom-end
Knife-edging
L\weight Flywheel
1875 cc (almost 1900cc)
But still its hitting me hard on the pocket , bread and water is all i can afford
Ported head
Cams
Forged Pistons
Balanced Bottom-end
Knife-edging
L\weight Flywheel
You ask to many Questions...
The cams will match Hennies work the compression will be around 8.3.
The piston needed very minor work basically just a very small pocket to clear the squinter as the skirt is just a bit to long
The Cams are not that far from stock as cams are hard to get...
The lifters have been redone again...
Hennies not working with the Cams at all and Yep Low boost now it will be 0.4 bar
Yep the actuator is fully adjustable currently at 0.3 bar...
I let the boost controller do all the work of keeping it at point 0.5 bar
Why Why Why ...... Fueling Fueling Fueling, I dont have the money for 440cc and a AFM at the moment maybe some day with my GT35
84.5 mm bore, becuase the piston is 84 mm and we need a 0,5 mm clearance for piston rings
the stroke in 83.6mm and the rod length is 133 mm so the 1875cc...
Well maybe Im wrong the stock motor is 1809cc stock
